Problem with Kwikset 916 z-wave lock
I just changed the batteries in one of my Kwikset 916 z-wave locks. I was testing with the dashboard to see if the lock reconnected to the hub, and the dashboard hung. Went into the device and same thing there, no commands were working. I finally tracked it down to the lock not fully engaging, but there was no indication by the hub of this, except an error in the log that finally made sense when I went to the lock.
Would it be possible to gracefully handle this situation, at least not make the dashboard and the device become unresponsive?
Incomplete 23 means the driver has no idea what the device is telling it, it also means no event was sent to Hubitat, it should return unknown for lock state, and now that I know that it means jammed, it will, but the lack of that event should not affect the dashboard, nor anything zwave related.
Thanks Mike! I swear, if there is some weird situation out there, I will find it :laughing:
when you joined this lock, did you need to manually change the driver?
It was some months back, so I don't remember...:slightly_smiling_face:
That particular lock is the newest of the three that I have.
can you just post me the data that's in the data section at the bottom of the driver?, I can check that way
