i noticed it is reporting every minute and even tried a configure again still no change.. not sure if it was doing this previously...
You are correct... I found setting the reporting interval not working. The reporting time is configVal3. I too could not get this to change regardless of how I set it using the default driver. I finally resorted to using the BasicZwaveToolDriver.groovy to set this parameter to the maximum 255. This was a little tricky since the driver seemed to only let me set it to a maximum of 127 since anything greater is considered a negative number.
State Variables
- refreshTemp : false
- configVal1 : 0
- configVal2 : 0
- configVal3 : 255
- configVal4 : 0
- configVal5 : 2
- lastBattery :
- refreshStatus : false
- reportedTemp : 79.6
what does 255 signify. dont really want it more than 5-10 minutes however not 1 minute
same issue mine will not set higher than 120.. we really need a driver fix from hubitat
a workaround is to run on battery which greatly reduces reporting time.. but this is no good as house is empty and battery dies..
