I have a dimmer button controller. It controls 3 lights. I configured button 4 to turn on all lights to the same level. Now I want to have each of the lights set to a different level but there is no option to expand the choices to set individual levels. I believe that there used to be.
It would be a big help if someone can tell me how to accomplish this.
It looks like you might be on an old version, though I don't recall any specific changes related to what you're seeing. It does seem like you probably turned off this option on the main page of the app after once having it turned on or now have only a single light selected after previously having multiple lights selected. Look under the "Advanced options" heading:
"Always show 'set for all' option even if only one dimmer/light selected..."
That should give you the option to disable the "Set for all lights" option on the page you're seeing and allow separate settings for each device -- although it also looks like you only have one selected so, as is, the outcome should be the same either way...
