[problem/question] default ENUMs in drivers (thermostat)
Hi all,
This morning I upgraded to version 2.3.4.117 and a custom Thermostat driver stopped working in my dashboards.
Perhaps my understanding is incorrect.
I created a minimal driver:
metadata {
    definition(name: "ThermostatTester", namespace: "a", author: "a") {
        capability "Thermostat"
    preferences {
When I add it to a dashboard and select mode (or fanmode), an error is thrown in the javascript console
SyntaxError: Unexpected token 'a', "auto,cool,"... is not valid JSON
    at JSON.parse (<anonymous>)
    at a.supportedThermostatModes (app.js?t=2.3.3:1:209170)
    at nr.get (chunk-vendors.js?t=2.3.3:7:30684)
    at nr.evaluate (chunk-vendors.js?t=2.3.3:7:31685)
    at a.supportedThermostatModes (chunk-vendors.js?t=2.3.3:7:33378)
    at a.vi (app.js?t=2.3.3:1:205695)
    at t._render (chunk-vendors.js?t=2.3.3:7:23733)
    at a.r (chunk-vendors.js?t=2.3.3:7:27824)
    at nr.run (chunk-vendors.js?t=2.3.3:7:31417)
I thought that there were sane defaults for enums (e.g. supportedThermostatModes)? Am I mistaken, do I have to implement them all?
Yes, there are no defaults for supportedThermostatModes, or an attribute name beginning with supported..
@mike.maxwell Great, thank you for a quick response!
I noticed where things are working different than before (been long ago that I wrote that driver):
metadata {
        capability "Configuration"
    preferences {
def configure() {
    sendEvent(name: "supportedThermostatModes", value: '["auto", "heat"]')
I previously passed in a list as value of sendEvent, that has to be changed to a (json) string now. That used to work.
(I am wonder what the "auto,cool," is doing in the stack trace)
