If you have a power strip with USB ports, can you plug a C-7 into those rather than using the adapter?
From the Hubitat Specs
All power supplies are USB 5 Volts @ 1 Amp, 100V to 240V.
If your strip can supply that as a good, stable, clean 5 Volts, you are set. Power is power.
