Presence sensors
C-8
The latest software update is making my presence sensors screw up now every time I leave it says I have left and then says I have arrived and sets off all of my automations meant for when I get home it’s messing with my garage door and door lock
Forgot to add I use a iPhone
We’ll probably need more information than that to be able to help troubleshoot.
Please describe in more detail what devices you’re using as presence sensors, and how you have configured automations to make use of the presence sensors.
Also I’m not clear on whether @user3991 and @asigner40 are the same person?
Don’t know why it has 2 Names but yes
I use hubitat app and OwnTracks and locative it’s affecting more locative than the other two but it still affecting all 3
restarted hub and phone and still didn’t fix the problem
Not sure what else you are looking for automations are simple and have been the same for months and never had a problem till the last hubitat update one is for my door lock and one is for my garage garage uses a zooz 16 with zooz driver door lock is Kwikset nothing special to the automations
This is what I mean.
There are many possible presence solutions.
The ones you have chosen to use require configuration. So please describe, or share some screenshots, of how you have configured the above three presence solutions.
Have you looked at the hub logs for any of the above?
Because you have two separate accounts...
Well whatever the problem was seems to have fixed itself for now
Just an observation - if you're seeing issues with the Hubitat App, Owntracks, and Locative all at the same time - my guess is that your hub temporarily lost its connection to the Hubitat cloud server. All three of those presence detection tools rely on the Hubitat Cloud to update the state of the presence devices on the hub.
If it happens again, my be good to see if the hub is connected to the Hubitat cloud or not.
