My HSM works great so far. It will Arm and Disarm by Presence (Life360) like it should with one exception. It does this fine in Day Mode but in Evening Mode I can not get it to work. I'm sure its some little something I'm missing. Any help is appreciated.
what is the rule you are using for disarming? can you screenshot it
I think your question caused me to understand why! I don't have a Disarming Rule. I guess HSM is doing it for me only for Day Mode (see attached) So I suppose I need a Rule for the Evening Mode. Would this be correct?
Are you able to select multiple modes in the drop down?
Yes, would that be the best solution? To just select Evening also
The first screenshot is from HSM. Wasn’t using a rule
You must have some type of rule setting the mode based on presence. You can go into the device and see whatever app/rules are using that device.
