Predicate false or not?
Hi all i'm confused about this situation, predicate is true or not?
The rule is not executed.
Turn on all of the logging for the rule. That will show you more information about what is or isn't happening. Need to see those logs for when 'Prior Ingresso Casa' opens. Use screenshot to show logs.
OK thanks
Hi
This time the rule had worked :frowning:
Log:>>
app:11982021-12-03 19:51:53.457 infoDelay Over: Color temperature per mode: Luce in Salotto Away: 6500, level: 100
Day: 6000, level: 50
app:11982021-12-03 19:51:51.930 infoSAL_TM_Movimenti In Salotto Rientro: Predicate Conditions now false
app:11982021-12-03 19:51:51.358 infoAction: On: MEM_Sono_a_Casa
app:11982021-12-03 19:51:51.349 infoAction: END-IF
app:11982021-12-03 19:51:51.335 infoAction: Color temperature per mode: Luce in Salotto Away: 6500, level: 100
Evening: 3000, level: 30
Night: 2700, level: 20
Ospiti: 6000, level: 80 --> delayed: 0:00:02
app:11982021-12-03 19:51:51.216 infoAction: Dim: Luce in Salotto: 10
app:11982021-12-03 19:51:51.210 infoAction: IF (Ci Vedo In Salotto(off) is off(T) AND
Illuminance of TriSensor Salotto(0) is < 100(T) [TRUE]) THEN
app:11982021-12-03 19:51:51.072 infoSAL_TM_Movimenti In Salotto Rientro Triggered
app:11982021-12-03 19:51:51.064 infoSAL_TM_Movimenti In Salotto Rientro: Porta Ingresso Casa contact open
The title always say , Predicate false , but now is true
Any ideas?
Sometime work sometime not but predicate is always false
Logging is your friend to see what is happening and why. When posting logs here, always use a screenshot, not copy/paste.
