Possible to use Apple Alarm event to trigger in Hubitat?
I am just wondering if Apple alarm clock could be use to trigger events in Hubitat via Homekit app?
By looking at Apple Homekit automation, I am guessing we create a virtual switch in Hubitat and create Homekit automation under "A Time of Day Occurs" selection and set it to trigger virtual switch or something?
Why not just use RM? Still setting a time somewhere, and I don't think you can tie directly into the alarm clock via shortcuts. Oops, just looked and you can tap into the alarm clock using shortcuts on iPhone.
Yes, iOS Alarms are supported as a shortcuts personal automation triggerโ€ฆ even while the device is locked. With that you can do an API call to maker API to control a device directly or to RM as a trigger to a bigger automation.
https://www.reddit.com/r/shortcuts/comments/tvnmjp/what_will_and_wont_run_when_the_device_is_locked/
