Properties
boolean isComponent - true or false, if true, device will still show up in device list but will not be able to be deleted or edited in the UI. If false, device can be modified/deleted on the UI.
Child device created from a device (not app).
Is there any way to change this after a child device is created? Or is only way to delete it and re-create it? I think I tried manually changing the value in the data field at one point but it did not change the way the child device functioned.
