My hub started getting network errors at 1 AM this morning, and has not recovered. This seems like a Daylight Savings Time issue.
I don't want to discount that entirely, but we changed about 3-4 weeks ago... Not saying I have successfully connected in that time... but...
Is it the ERR_TOO_MANY_RETRIES error?
Yes
Glad I didn't wager any money... and I thought I just had an edge-case issue... I still prefer Daylight Savings... But I feel that is more of a "lounge" conversation... ![]()
My ASUS router appears to have the DST issue. It was misbehaving to some clients, but not all. I rebooted the router, and the problem has gone away (until next year).
So this then? (not a time change issue)
I had this on Chrome on my phone the other day. I fixed it with: https://community.hubitat.com/t/2-5-3-108-cannot-get-to-hub-from-chrome-on-android-phone-pixel-8-pro/167107/11?u=jlv That's in the beta forum. In case you aren't in it:
(Somehow, the setting got "lost" even though it was set on).
On my wife's phone this permission was off. I needed to turn it on for it to work at all.
If you recently upgraded to Android 17, you have to go back in and allow this specifically again for every app that needs it.
I was a little irked that they did not advertise this (as usual) prior to accepting the update on my phone.
Had to fix Hubitat, Tasker, Home Assistant, Folder Sync, and a few others that needed this permission.
Interesting...
I updated to Android 17 back in July. I definitely used the browser to access my hub since then. The last system patch update I had was on October 5, and I'm pretty sure I re-paired a Zigbee device on the 7th and 14th (every time I replace a battery in an Iris V2 device I need to re-pair them, and I use my phone for that purpose).
Apparently, Samsung and/or Verizon wanted to hold off on that for a bit for its users (my Tab S9 still hasn't seen it)
For me, it was the apps, not the browser, that needed LAN access. Luckily for me, Home Assistant tried to connect immediately on reboot prompting me to check everything else. All of them had a prompt to fix them when I opened them. It was just that I would not have known until they didn't work (like Folder Sync, which I have set to back up my photos at 1 AM)
I forgot about my WG tunnel until it tried to determine if I was on my home lan or not when I returned home. Interesting, it only failed on local LAN. Over cellular data, it worked just fine.
Thanks, I'll test this when I am next "nearby" the hub ![]()
