Possible bug in New Rule Machine
I created a new trigger, in the new rule machine, to run a rule every 5 mins but then decided to change that to every 2 mins. However, after editing it is still displayed in the rule as 5 mins. I had to delete the trigger and recreate it.
Dumb question did you click "done" all the way out? I just did a rule like this to test and had no problem changing the timing.
Good point. :slight_smile: Not all of the way out but I did click Finish with Triggers and added some actions and it remained.
Edit:
I can change it okay and if I re-edit it shows the changed duration. It's only the overview when editing the rule that still shows the original duration.
Yeah you have to click DONE to completely save/update the rule
