@mike.maxwell@bravenel I may have discovered a bug in either RM or the upadted Hue Integration. If I use a set color action on a Hue rgbw bulb (huebridgebulbrgbw) I get the following error:
Strangely enough, I can use the same command in button controller with no issue. So, for now, I created a virtual button device and am using button controller to invoke the command.
Edit: I also got this error trying to save the button controller for the action, but I was able to page back and then it saved:
app:51862018-11-28 09:36:43.639 pm errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.util.HashMap) values: [[p:2]] Possible solutions: wait(), any(), wait(long), each(groovy.lang.Closure), any(groovy.lang.Closure), take(int) (mainPage)
I also started seeing this which I never saw before in my logs:
2018-11-29 11:07:00.086 am [debug](http://192.168.13.46/installedapp/configure/1)found Hue Bridge (2F2FCD) with id 0017882F2FCD already exists
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:07:00.054 am [debug](http://192.168.13.46/installedapp/configure/1)Initializing
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:06:00.176 am [debug](http://192.168.13.46/installedapp/configure/1)found Hue Bridge (2F2FCD) with id 0017882F2FCD already exists
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:06:00.052 am [debug](http://192.168.13.46/installedapp/configure/1)Initializing
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:05:00.142 am [debug](http://192.168.13.46/installedapp/configure/1)found Hue Bridge (2F2FCD) with id 0017882F2FCD already exists
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:05:00.050 am [debug](http://192.168.13.46/installedapp/configure/1)Initializing
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:04:00.225 am [debug](http://192.168.13.46/installedapp/configure/1)found Hue Bridge (2F2FCD) with id 0017882F2FCD already exists
[app:1](http://192.168.13.46/logs#app1)2018-11-29 11:04:00.100 am [debug](http://192.168.13.46/installedapp/configure/1)Initializing
