I moved two room lighting rules from one hub to another, both were exported successfully, but with one minor issue.. The one for my kitchen lighting has 6 lights. I have 2 lighting periods based on mode. In one mode 4 of 6 lights should be activated in the other mode only 1 of the 6 lights should be activated.
After import all lights in both modes were set for activation. Everything else seemed to be correct. Don't really have any other rules to move to try again. So just thought I would report, maybe it was just a one off due to my configuration.
[Edit] Just noticed another error. Under turn off when buttons are pressed I had it set to turn off when a certain button 2 was doubleTapped, after import it was set to button 2 pushed.
Were the devices on the moved-to hub identical to the devices on the moved-from hub? Export/Import is very straight forward, and it knows nothing about the innards of most apps, including Room Lights. It just creates an app with the same settings and state as the original. Presumably since you moved it to a different hub, you had to select the devices to use. Modes could be very problematic in this, as modes have internal id numbers, and there is no reason to think they'd be the same on two different hubs. None of Export, Import or Room Lights would have any way to know that.
This is not the sort of thing that can be investigated, nor is it worth investigating.
In this case yes, exactly the same. The RL rule was originally residing on a hub that just contains rules and accesses the devices via hub mesh. I have decided that perhaps for some things, specifically room lighting rules, it would be better for the rule to reside on the hub with the devices. So in this case there was no change other than moving from a mesh device to the actual device.
Also the modes are shared and the hub the Rl rules came from is the hub that sets the mode and the other hub follows it.
