I just ordered the C-8 hub to replace my C-7 hub. I live in a 2,500 sq. ft., 1 floor rectangular condo. Right now I have my C-7 fairly centrally located on the north-south axis, but is more to the west side on the condo on top of a wooden hutch that is about 7 feet tall. I have about 30 Z-Wave Plus devices (mostly Inovelli Red, Black and Fan+Lights), 3 FIbaro Key Fobs, and several smart plugs. (I also have a couple of Aeotec 7 repeaters that seem to do nothing). and 1 Zigbee motion sensor about 15 feet from the Hub (and it works just fine).
I have 2 questions:
Does it matter if I place the antennas in line with the north-south axis, 45 or 90 degrees from that? (i.e. does leaving it flat, but rotating it matter?). I know every place is a bit different, but I'm looking for "in general" answers.
Because the C-7 was so thin it is invisible on top of the hutch as long as I put it about 1 foot from the front of the hutch. However, the antennas on the C-8 will make those visible. I have a few choices and I'm looking for placement opinions.
I have a flag displayed in a triangular frame with a glass front. I could put the C-8 behind that, but I don't know how much the flag and glass would block the Z-Wave/Zigbee signals.
Another possibility is that the hutch actually has a pressboard top that does not extend the whole width of the hutch (to allow access to some built in lights that illuminate the shelves). I could possibly put it in a corner of the hutch the pressboard doesn't cover, but then it would be very close to the TP-Link satellite wi-fi unit it is plugged into via an RJ45 and, would be sunken a bit, so it would have the solid wood of the hutch around most/all of the antennas.
I could also put it inside the hutch (which, again is all wood except for 1 glass shelf) and/or try to hide it behind a picture I have on a shelf on the hutch (the picture is canvas with a wood frame and no glass but there would be a glass shelf either above or below it).
One other alternative is that I could sit it on an end table that is in the corner of that room, but it would then be much lower and much more to the west wall of the condo.
Any of those sound better than the other?
