Maybe the issue is that the app shows that the power is off although the LG tv is currently on?
Upon further investigation it seems that the LG app can power the TV off but not power it on
I figured it out. There's a companion app that goes with the driver thaht discovers your TV. You run that then click to accept on your TV and it populates the key.
Do you know if WOL works with C9 tv?
Afraid not, easy enough to try and see.
Yeah, I tried and it didn't work but maybe I'm doing something wrong
Happy to help -- tell me what you did, which app you used, and we can compare notes!
Thanks! So I download the LG webOS driver (Which is now with your revised code).
I also downloaded the WOL app. Added to the app my LG C9 TV as a device and added to it the MAC&IP address of the tv.
Now, if I press "on" on the WOL device, I get this warning line in the log section..."Error occured with UDP message: SocketTimeoutException: Receive timed out".
I also created a basic rule (Please see attached screenshot) but it didn't work.
Which WOL app are you using? I had some trouble too until I used this one. Maybe give it a try. Worked for me.
Yep, I'm using this one
Hmm maybe others can comment. I believe the TV has to support WOL and there is usually some setting that allows the TV to operate at a low power sleep state. Maybe check that out?
Also I believe your router has to allow WOL as well.
A couple places to look for solutions?
I'm going to chime in. It's been awhile but I installed this app some years back. Seems I had trouble in wol.
I think I wound up having wifi and Ethernet both connected on the TV. One of the two would respond to wol the other wouldn't..
Thanks but no change even with wifi on
I think I need to find out how to allow WOL on my router
The driver worked great for me, including power-on (my TV is connected only to wi-fi). I made one enhancement, adding this one line to the metadata:
capability "Actuator"
That allows me to actually access the values of the Command variables in a rule. I now have the TV responding to a power-on event by turning on my Denon receiver AND switching to YouTubeTV (just set the externalInput to "YouTube TV").
can you post the rule? I've been trying to do somethin gsimilar with some lights and never quite have been able to get it to work reliably. You'd t hink it would be simple but apparently not for me
Sure thing. Rules are tricky, especially the obscure way to set parameters for custom devices.
Hopefully these screen snaps help (not sure if I know how to add pictures!)...
Yeah I have something similar. (Are you missing an ENDIF btw?) The problem I have is sometimes when I turn the TV on physically the device driver just never realizes it.
Yes, sometimes it misses the "on" event, but it mostly works. And thanks for catching that! Added the ENDIF!
Hey sorry, don't come here too often any longer so didn't see your response.
I think I explained it somewhere in this thread above but the app has to do a poll to determine when the TV is on. Basically, webconnect has to reconnect before the TV is on. The timing of that poll is customizable. In the preferences, the poll is called "Device Reconnect Delay". I've set mine to 30s.
So what that means is that it could take a max of 30s after the TV is on before the app notices that. That might be what you're experiencing.
Also, you'd want to turn "Quick Start+" on. That's what allows it reconnect quickly.
