Port finished, nothing left on the st hub.
Just in time as i believe the classic app is going away tomorrow.
I had issues with two devices the keen vent will not return the correct temp.
And the quibino weather statilon has a stick that installed fine and showed configure etc fine. in logs but no data on its various channels ever seem to trickle in to the stick.. Worked fine in st..
I will try again on an older hub version i bought a couple years ago and still have in the box.
Replaced all switchs both in wall and plugs, and plug in with zwave plus, also all door sensors are zwave plus or zigbee. Garage door 1 is zwave plus relay and sensor, 2 is gd00z-8 also all zwave plus. Only one non plus device still around a ge fan controller that was hard to get too and seems to work fine.. I dont need to read the status anyway as I only turn it on off via an automation.
All Dashbords by rooms, and capabilities completed..
Still waiting for smart ups to get the monitoring and clean shutdown on this hub.
88 zwave devices
37 zigbee and the remainder konnected windows, doors from old alarm, and various virtual and custom devices such as honeywell therms , etc.
