You are going to need to be much more specific about what you are doing, what steps you've taken, where you're having trouble.
I suspect based on your previous comments, you're stuck trying to get a tile to display the status of your Plex player.
There's a few things you could try. You could create a custom state based on the state of the player and feed that into a title using the "state" template. Similarly you could try to export the text of the webhook status and feed that into a "text template." Or try it with creating a variable and have the variable string template.
I'm not home, so I can't test. But what I believe you want to do is pick your Plex device and then use the "Attribute" tile. You should be able to pick from mode status, last updated, playback type, or status.
you still didn't say what you were already trying.
i have a tile with status but it does not update says stopped when im watching a movie with plex
when i select the player from the drop down it does not show the play icon next to my player when its playing a movie
How do i do a screenshot to show you more im on windows 10
Google is your friend. Respectfully, if capturing a screenshot isn't something you know how to do, you may be a bit over your head here.
Did you choose the "attribute" title? It is a specific tile.
I don't know what you expect the tile to show. The attribute tile should just show the word "playing" when it is playing, since that is the attribute you are reading.
And again, you haven't said specifically what you did. You just said "you have a tile with status." Which tile did you pick?
You are going to need to provide more detail if you want people to help you.
I'm not at home, so I can't compare, but it looks like you don't have the right device picked for the tile. In my dropdown for picking a device, I have the specific player listed. So the device you should be picking should be "Majesty Pro LTE" or "MyCloudpr2100" or whichever the PlexCommunicator device is that was making your lights work.
You shouldn't be choosing "plex" from the list. That isn't the device that PlexCommunicator is monitoring.
In theory it's possible, but the code would need to be updated.. if you ever wanted to try to learn some basic coding, this is how I learnt to program.. start with someone's code, work out what it does and then update it to do more!
Does anybody have the exe working on HE?
I can get it running fine but am unsure of what the correct paths need to be in the config file as I can only find one to send the status to smartthings.
The exe doesn't seem to be passing the plex device identifier through so I had to change the the device network id to the the player name and change the app code to get HE to send it to the correct device.
First of all, @jebbett ebbet thanks for writing a kickass app. I got it up and running and I am seeing JSON events coming into HE from my Plex server and I see them like this as an example:
Event JSON: media.pause
But something weird is happening with Plex running on Apple TV. If I play or pause a movie in Chrome or any other device the Media Scene stuff gets triggered and everything works great. Except when I use Plex on Apple TV. I have spent hours last night trying to figure out if it's a device ID issue, I uninstalled and reinstalled the Plex device, etc. I cannot figure out for the life of me why this works everywhere except with the Applex TV Plex App.
Have you see this before? Do you have any suggestions?
