No sorry,...but I've just had a go at porting it over.. but I am also unable to test it!
It should* work, but there is a good chance it wont.. So give it a go and send me any logging where there are errors and I'll aim to fix quickly!
Parent
* Media Scene
* Copyright 2018 Jake Tebbett
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* VERSION CONTROL - Media Scene
* v1.0 - Initial Release
definition(
namespace: "jebbett",
author: "Jake Tebbett",
description: "Control scenes based on media state and type",
category: "My Apps",
iconUrl: "https://github.com/jebbett/MediaScene/raw/master/Icons/MediaScene.png",
iconX2Url: "https://github.com/jebbett/MediaScene/raw/master/Icons/MediaScene.png",
iconX3Url: "https://github.com/jebbett/MediaScene/raw/master/Icons/MediaScene.png"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
preferences {
page name: "parentPage"
def parentPage() {
dynamicPage(name: "parentPage", title: "Rooms", install: true, uninstall: true, submitOnChange: true) {
section {
app(name: "childapp", appName: "MediaSceneChild", namespace: "jebbett", title: "Create New Room", multiple: true)
section {
input(name: "debugLogging", type: "bool", title: "Enable Debugging", required: false)
Child
* Media Scene
definition(
parent: "jebbett:MediaScene",
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
state.catcherRunning = false
subscribe(playerDT, "status", PlayerDTCommandRecieved)
preferences {
page name: "childPage"
//Child Pages
page name: "pageDoThis"
page name: "pageWhenThis"
page name: "pageMediaSettings"
def childPage() {
dynamicPage(name: "childPage", uninstall: true, install: true) {
section() {
label title: "Enter Room Name", defaultValue: app.label, required: false
section ("For This Device"){
input(name: "playerDT", type: "capability.musicPlayer", title: "Media Player Device", multiple: false, required:false)
section("Lights") {
input "dimmers1", "capability.switchLevel", title: "Adjust level of these bulbs", multiple: true, required: false, submitOnChange: true
input "hues1", "capability.colorControl", title: "Adjust level and color of these bulbs", multiple:true, required:false, submitOnChange: true
if(hues1||dimmers1) {
input(name: "iLevelOnPlay1", type: "number", title: "Level on Play", defaultValue:0)
input(name: "iLevelOnPause1", type: "number", title: "Level on Pause", defaultValue:30)
input(name: "iLevelOnStop1", type: "number", title: "Level on Stop", defaultValue:100)
if(hues1) {
input "colorOnPlay", "enum", title: "Hue Bulbs > Color On Play", required: false, multiple: false, submitOnChange: true,
options: ["Soft White", "White", "Daylight", "Warm White", "Red", "Green", "Blue", "Yellow", "Orange", "Purple", "Pink"]
input "colorOnPause", "enum", title: "Hue Bulbs > Color On Pause", required: false, multiple: false, submitOnChange: true,
input "colorOnStop", "enum", title: "Hue Bulbs > Color On Stop", required: false, multiple: false, submitOnChange: true,
input(name: "tempOnPlay", description: "1000..9999", type: "number", range: "1000..9999", title: "Color Temperature on Play (°K)", required: false)
input(name: "tempOnPause", description: "1000..9999", type: "number", range: "1000..9999", title: "Color Temperature on Pause (°K)", required: false)
input(name: "tempOnStop", description: "1000..9999", type: "number", range: "1000..9999", title: "Color Temperature on Stop (°K)", required: false)
input(name: "bDimOnlyIfOn1", type: "bool", title: "Dim bulbs only if they're already on", required: false)
section("Switches") {
input "switches2", "capability.switch", title:"Switches On when Playing", multiple: true, required: false
input "switches1", "capability.switch", title:"Switches Off when Playing", multiple: true, required: false
input(name: "bReturnState1", type: "bool", title: "Switches return to original state when Stopped", required: false)
input(name: "bSwitchOffOnPause1", type: "bool", title: "Switches use Play config when Paused", required: false)
input(name: "switchOnPlay", type: "bool", title: "Switches only change on 'Play'", required: false)
paragraph "The below switches do not toggle off when state becomes inactive, ideal for tiggering external App scenes"
input "mSwitchPlay", "capability.switch", title:"Momentary switch on Play", multiple: true, required: false
input "mSwitchPause", "capability.switch", title:"Momentary switch on Pause", multiple: true, required: false
input "mSwitchStop", "capability.switch", title:"Momentary switch on Stop", multiple: true, required: false
section("Modes") {
input "playMode1", "mode", title: "Mode when playing", required:false
input "pauseMode1", "mode", title: "Mode when paused", required:false
input "stopMode1", "mode", title: "Mode when stopped", required:false
section("Routines") {
def actions = location.helloHome?.getPhrases()*.label
input "playRoutine", "enum", title: "Routine when playing", required: false, options: actions
input "pauseRoutine", "enum", title: "Routine when paused", required: false, options: actions
input "stopRoutine", "enum", title: "Routine when stopped", required: false, options: actions
section("Media Settings") {
input(name: "bTreatTrailersAsPause1", type: "bool", title: "Use pause config for movie trailers", required: false)
input(name: "stopDelay", type: "number", title: "Delay stop action", required:false, defaultValue:0)
input(name: "pauseDelay", type: "number", title: "Delay pause action", required:false, defaultValue:0)
section("Restrictions") {
input "mediaTypeOk", "enum", title: "Only for media types:", multiple: true, submitOnChange: true, required: false,
options: ['movie', 'episode', 'clip', 'track']
input "disabled", "capability.switch", title: "Switch to disable when On", required: false, multiple: false
input "activeMode", "mode", title: "Only run in selected modes", multiple: true, required:false
// Recieve command from MusicPlayer device type
def PlayerDTCommandRecieved(evt){
def mediaType = playerDT.currentplaybackType ?: null
if(evt.value=="playing"){ AppCommandRecieved("onplay", mediaType)}
else if(evt.value=="stopped"){ AppCommandRecieved("onstop", mediaType)}
else if(evt.value=="paused"){ AppCommandRecieved("onpause", mediaType)}
def AppCommandRecieved(command, mediaType) {
// Stop running if disable switch is activated
if (disabled != null) {if(disabled.currentSwitch == "on") {logWriter ("Disabled via switch"); return}}
if (activeMode != null && !activeMode.contains(location.mode)) {logWriter ("Disabled via invalid mode"); return}
// Check if Media Type is correct
if(mediaTypeOk){
def mediaTypeFound = mediaTypeOk.find { item -> item == mediaType}
if(mediaTypeFound == null) {logWriter ("Match NOT found for media type: ${mediaType}"); return}
//Translate play to pause if bTreatTrailersAsPause is enabled for this room
if(settings?.bTreatTrailersAsPause1 && mediaType == "clip" && command == "onplay") {command = "onpause"}
// Unschedule delays
unschedule(StopCommand)
unschedule(PauseCommand)
// Play, Pause or Stop
if (command == "onplay") {
logWriter ("Playing")
PlayCommand()
else if (command == "onpause") {
logWriter ("Paused")
if(!settings?.pauseDelay || pauseDelay == "0"){
PauseCommand()
}else{
logWriter ("Pause Action Delay")
runIn(settings?.pauseDelay.value, PauseCommand)
else if (command == "onstop") {
logWriter ("Stopped")
if(!settings?.stopDelay || stopDelay == "0"){
StopCommand()
}else{
logWriter ("Stop Action Delay")
runIn(settings?.stopDelay.value, StopCommand)
def PlayCommand(){
if(!state.catcherRunning){
catchState("switches1")
catchState("switches2")
state.catcherRunning = true
if(settings?.playMode1){setLocationMode(playMode1)}
SetLevels(iLevelOnPlay1, colorOnPlay, tempOnPlay)
SetSwitchesOff()
mSwitchPlay?.on()
if(playRoutine) { location.helloHome?.execute(playRoutine) }
def PauseCommand(){
if(settings?.pauseMode1){setLocationMode(pauseMode1)}
SetLevels(iLevelOnPause1, colorOnPause, tempOnPause)
mSwitchPause?.on()
if(pauseRoutine) { location.helloHome?.execute(pauseRoutine) }
if(settings?.bSwitchOffOnPause1) {
SetSwitchesOff()
} else {
if(state.catcherRunning && settings?.bReturnState1){
returnToState("switches1")
returnToState("switches2")
}else{
SetSwitchesOn()
//Stop command
def StopCommand(){
if(settings?.stopMode1){setLocationMode(settings?.stopMode1)}
SetLevels(iLevelOnStop1, colorOnStop, tempOnStop)
mSwitchStop?.on()
if(stopRoutine) { location.helloHome?.execute(stopRoutine) }
}else{
SetSwitchesOn()
// Actions
def SetSwitchesOn() {
if(!switchOnPlay){
switches1?.on()
switches2?.off()
def SetSwitchesOff() {
switches1?.off()
switches2?.on()
def SetLevels(level, acolor, temp) {
// If color specified set hues
if (level != null) {
def hueColor = 23
def saturation = 56
switch(acolor) {
case "White":
hueColor = 52
saturation = 19
break;
case "Daylight":
hueColor = 53
saturation = 91
break;
case "Soft White":
hueColor = 23
saturation = 56
break;
case "Warm White":
hueColor = 20
saturation = 80 //83
break;
case "Blue":
hueColor = 70
break;
case "Green":
hueColor = 35
break;
case "Yellow":
hueColor = 25
break;
case "Orange":
hueColor = 10
break;
case "Purple":
hueColor = 75
break;
case "Pink":
hueColor = 83
break;
case "Red":
hueColor = 100
break;
if (settings?.bDimOnlyIfOn1){
if(acolor != null){ hues1?.each { hue -> if ("on" == hue.currentSwitch) { hue.setColor([hue: hueColor, saturation: saturation, level: level]) } } }
else if(temp != null){ hues1?.each { hue -> if ("on" == hue.currentSwitch) { hue.setColorTemperature(temp) } } }
else { hues1?.each { hue -> if ("on" == hue.currentSwitch) { hue.setLevel(level) } } }
dimmers1?.each { bulb -> if ("on" == bulb.currentSwitch) { bulb.setLevel(level) } }
}else{
// color takes priority over temperature, dimmers will still set temperature if available
if(acolor != null){ hues1?.setColor([hue: hueColor, saturation: saturation, level: level]) }
else if(temp != null){ hues1?.setColorTemperature(temp) }
dimmers1?.setLevel(level)
//Save state
private catchState(switches) {
settings."${switches}"?.each { switcher -> state."${switcher.id}State" = switcher.currentValue("switch")
logWriter (switcher.currentValue("switch"))
//Return to state
private returnToState(switches) {
settings."${switches}"?.each {switcher ->
if(state."${switcher.id}State" == "on") {switcher.on()}
if(state."${switcher.id}State" == "off") {switcher.off()}
//// GENERIC CODE
private def logWriter(value) {
if(parent.debugLogging) {log.debug "Media Scene [${app.label}] >> ${value}"}
