I've never seen mine loose state either it's been very reliable.
Quick question: I'd like to set up this for a fan/light at my parents house, but they don't have a hub yet. The switch should still work manually without a hub, correct? (I'm assuming yes because the switch communicates with the controller thru RF, but just wanted to verify)
Works and can be configured with or without a hub.
The Inovelli fan/light controller is a great option for old houses with knob and tube wiring where you don't have a neutral at the switch if there's a convenient place for the smart switch that you can reach with new wiring. (With the Inovelli fan/light switch, the module in the fan housing doesn't have to be on the same circuit as the smart switch.) I put a dumb light switch in the existing switch location with a cover on it to keep it from getting turned off, then I ran new wiring to a new location for the smart switch. Works great!
