// flags are: 1 - changed global brightness, 2 - changed pattern
def setLastControlChange(Long flags) {
// get current control change flags,add new flag and
// save
c = Long.valueOf(device.getDataValue("lastControlChange"))
c = c | flags
Is it any updates I am missing?
If "no" is it easy way to fix the driver?
EDIT
Surprisingly only one out of 7 Pixelblaze Controllers exhibit this problem. All they are using
the same driver but running different patterns.
This may have been caused by a recent Hubitat update. I can't reproduce it here, but at least one other person has seen something similar. Try the following and see if the error goes away:
reboot your hubitat
go to the affected device's "Device" page and press "Initialize" to reset the all the driver's internal variables. (Optionally, you can also press "Get Patterns" while you're there to reload the pattern cache.)
Let me know if this helps!
(And if it doesn't, since it's only 1 of 7 pixelblazes, it might be interesting to check if the one that throws the exception is running different firmware than the others.)
