Pick remote and dimming
I have a couple pico remotes and I have those working just fine. What I would like to know is it possible is when I hold the app or the down arrow for the lights to get dimmer or brighter and then stop when I release the button I have my light set an a group, I don’t know if that’s the right way to do it or not?
I think if the bulbs support the start level change and stop level change command and the button device support the held and release commands then it should work.
I have a Zen34 doing that with a Sengled bulb connected to a C7. What I am not sure is how the idea of a group effects that.
Yeah, I’m kind of new to all this so I’ve been trying to monkey with it and play around with it. Their hue bulbs in the hue app or HomeKit. You know I can slide the slider up and down and change them so I’m not exactly sure what I’m doing wrong.
It depends upon how you set up your Pico. Did you bring them in as Fast Pico, or Pico? The Pico exposes more options.
You can't, as far as I know, change just the driver in the Device tab. You need to fix/change the Lutron Integration Type for this device to Pico, then delete the old Fast Pico device in Devices tab. Otherwise you end up with two devices, one will be non-functional.
I think I have them set as fast pico. I will delete them and try again and let you know how it goes. Thank you for your help.
