There's a trigger for a Physical Switch and Physical Dimmer Level, I'd like to see something similar for thermometers. Occasionally my wife wants to use the thermostat to turn the AC on/off while I have it configured to use a rule.
I'd like a trigger so that if the thermometer was adjusted manually, Pause my rule.
Is there anything in the works that can capture the physical thermometer adjustments?
