Phishing Perhaps
I have two C7 hubs, both on the same network. I just noticed that the logs on one include about twenty consecutive entries like the following:
sys:12022-09-10 05:24:43.028 pm Received cloud request for App 2289 that does not exist, path: /device/460 from 34.229.187.57
sys:12022-09-10 05:24:43.028 pm Received cloud request for App 2289 that does not exist, path: /device/1154 from 54.159.73.222
sys:12022-09-10 05:24:43.026 pm Received cloud request for App 2289 that does not exist, path: /device/1152 from 3.87.218.211
I can't imagine who or what would be doing this. Each requesting IP address is different.
Any ideas?
Mike M.
Sounds like you’ve recently removed an integration from your hub, but didn’t shut down the other side.
Yes, thanks. Apparently, all those IP addresses belong to Amazon's Alexa.
I found the following in the logs:
app:22892022-01-03 09:39:45.343 am errorError making Call to Alexa message gateway: null
app:22892022-01-03 09:39:45.321 am errorError making Call to Alexa message gateway: null
What prompted Alexa, I cannot say.
I thought I had reset the Hub but the logs refer to apps and devices that were there long ago.
Learning something new every day - - - -
Mike M.
You reset the hub, so removed the app, but if you do not go into the Alexa app and unlink it from hubitat it may still be trying to talk to your hub which will cause those error. Same with any other services you integrated to with the hub.
