Hello.
I'm new here and trying to find some answers if hubitat is a good system to buy.
Right now I'm using iobroker on a beelink mini pc with mostly Xiaomi/ aqara sensors and switches. I also use some Phillips zhirui candle and downlight lights.
I wonder if a can still use them with hubitat. Because they are WiFi based.
They however work through the mi home app.
They work in iobroker but I have to connect them with a token.
There's definitely no native integration for this (I'm assuming they're different from Yeelight, but if they aren't there is a native integration for that). I'm not sure if anyone has found workarounds. This thread on ST might help, but it still doesn't look promising, and I'm not sure if this is exactly the same device: Xiaomi Philips Smart LED - Deals - SmartThings Community.
It might be possible for someone to create an integration--I see Home Assistant has an integration: Xiaomi Miio - Home Assistant (also requires you to get the token; I'm guessing this is normal for these devices since the manufacturer usually doesn't intend for them to be used outside their "native" ecosystem and these are probably unofficial workarounds). You can sort of integrate Home Assistant devices into Hubitat via MQTT (via one of two currently unofficial methods) if you're willing to add another layer or two of complexity to your setup, so if you're desperate, that could work.
Perhaps someone else can chime in if they have personal experience with these devices. I had never heard of them before, and a Hubitat forum search reveals nothing, so I'm assuming not.
