Trying to control a Philips Warm White Dimmable Wiz bulb. I installed the Wiz Integration, and it sees the bulb at the proper IP address as a Stub.. which I do not have On/Off/Dim functions. When I change to the Wiz RGBW, I can then see all the functions, but it does not control the bulb. Is there something I am missing here?
BTW - Bulb works fine with app.
Problem solved. Needed to change from the stub to the RGBW. Then enter the IP address into the RGBW. All works!!
