Philips Wiz Color Light Driver as Virtual Device
@zranger1, I have a general question about this driver related to using it as a Virtual Device.
I have a entry light into my home that has 8 Wiz bulbs in it. I have used both a Virtual RGBW Bulb driver tying them together with things like Switch Bindings, Rule Machine, Switch Bindings, etc. I also have used a RL Activator device in the past to control these 8 bulbs as a group.
Is it possible to use this driver as a Virtual Wiz Bulb to group together other real physical bulbs? I'm assuming I can as long as I'm passing the custom attributes between them? For the Virtual instance I'm assuming I can just leave the IP address blank or just put in some bogus address there?
Just trying to emulate the bulb groups that you can create in the Wiz V2 app using Hubitat is all.
