unfortunately the flood sensor doesn't work (and isn't shown in the device edit page). Here is the log:
dev:4182022-05-26 08:58:21.592 pm info_znNassFeuchtTemp_Waschr: humidity is 48.06%
dev:4182022-05-26 08:58:21.590 pm debug_znNassFeuchtTemp_Waschr humidity sensor value is 48.06%
dev:4182022-05-26 08:58:21.578 pm info_znNassFeuchtTemp_Waschr: temperature is 25.31°C
dev:4182022-05-26 08:58:21.576 pm debug_znNassFeuchtTemp_Waschr temperature sensor value is 77.55°F (25.31°C)
dev:4182022-05-26 08:58:21.516 pm warnUnhandled cmd: SensorBinaryReport(sensorValue:0, sensorType:6)
dev:4182022-05-26 08:58:21.453 pm info_znNassFeuchtTemp_Waschr: battery is 31%
dev:4182022-05-26 08:58:21.196 pm info_znNassFeuchtTemp_Waschr: humidity is 48.06%
dev:4182022-05-26 08:58:21.194 pm debug_znNassFeuchtTemp_Waschr humidity sensor value is 48.06%
dev:4182022-05-26 08:58:21.178 pm info_znNassFeuchtTemp_Waschr: temperature is 25.31°C
dev:4182022-05-26 08:58:21.176 pm debug_znNassFeuchtTemp_Waschr temperature sensor value is 77.55°F (25.31°C)
dev:4182022-05-26 08:58:21.116 pm warnUnhandled cmd: SensorBinaryReport(sensorValue:255, sensorType:6)
dev:4182022-05-26 08:58:21.057 pm info_znNassFeuchtTemp_Waschr: battery is 33%
dev:4182022-05-26 08:58:16.472 pm info_znNassFeuchtTemp_Waschr: humidity is 47.09%
dev:4182022-05-26 08:58:16.469 pm debug_znNassFeuchtTemp_Waschr humidity sensor value is 47.09%
dev:4182022-05-26 08:58:16.220 pm info_znNassFeuchtTemp_Waschr: temperature is 25.30°C
dev:4182022-05-26 08:58:16.218 pm debug_znNassFeuchtTemp_Waschr temperature sensor value is 25.30°C (25.30°C)
dev:4182022-05-26 08:58:15.975 pm info_znNassFeuchtTemp_Waschr: battery is 33%
dev:4182022-05-26 08:58:15.721 pm debug_znNassFeuchtTemp_Waschr wakup interval 600 minutes
dev:4182022-05-26 08:58:15.199 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 15, size: 1, configurationValue: [12], scaledConfigurationValue: 12)
dev:4182022-05-26 08:58:14.710 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 14, size: 1, configurationValue: [12], scaledConfigurationValue: 12)
dev:4182022-05-26 08:58:14.195 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 13, size: 1, configurationValue: [12], scaledConfigurationValue: 12)
dev:4182022-05-26 08:58:13.689 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 10, size: 1, configurationValue: [12], scaledConfigurationValue: 12)
dev:4182022-05-26 08:58:13.186 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 20, size: 1, configurationValue: [30], scaledConfigurationValue: 30)
dev:4182022-05-26 08:58:12.682 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 23, size: 1, configurationValue: [5], scaledConfigurationValue: 5)
dev:4182022-05-26 08:58:12.193 pm debugConfigurationReport: ConfigurationReport(parameterNumber: 21, size: 1, configurationValue: [1], scaledConfigurationValue: 1)
dev:4182022-05-26 08:58:11.731 pm debugVersionReport: VersionReport(zWaveLibraryType:3, zWaveProtocolVersion:4, zWaveProtocolSubVersion:5, firmware0Version:1, firmware0SubVersion:8, hardwareVersion:1, firmwareTargets:1, targetVersions:[[target:1, version:1, subVersion:6]])
dev:4182022-05-26 08:58:11.538 pm warnUpdating device wakeUpInterval: 600
dev:4182022-05-26 08:58:11.534 pm warnUpdating device waterInterval: 12
dev:4182022-05-26 08:58:11.531 pm warnUpdating device humidityInterval: 12
dev:4182022-05-26 08:58:11.527 pm warnUpdating device temperatureInterval: 12
dev:4182022-05-26 08:58:11.523 pm warnUpdating device batteryInterval: 12
dev:4182022-05-26 08:58:11.520 pm warnUpdating device tickInterval: 30
dev:4182022-05-26 08:58:11.516 pm warnUpdating device humidityDifferential: 5
dev:4182022-05-26 08:58:11.513 pm warnUpdating device temperatureDifferential: 1
dev:4182022-05-26 08:58:11.511 pm debugdeviceSync: pendingResync true, pendingRefresh true
