The reason I originally was interested in smart smoke detectors was because of the extra sensors/notification possibilities. My family does not want to see a bunch of sensors around reading the temperature, monitoring their motion, etc... but they like the outcome of some of it (as long as it is all hidden behind the scenes).
Nest Protect had a lot of sensors... but made it tough to get access to them. Tried one early on, found it too constrained. The Halo detectors made accessing data much easier (but no motion) and were local only, got a few of them.
So I was able to replace most of the normal smoke detectors with Halo, and some of the other sensors. Family just saw smoke detectors in smoke detector spots. Completely ignored, not even within notice. But they provided those temperature and humidity (pressure not so relevant) readings readily. Plus, they had an LED ring built in. This allowed me to have them act as a nightlight in some spots or change the color and brightness for notifications (smoke detectors are glowing bright blue, there is a water leak with my aquarium was one).
So in reality, it is not so much about having a smoke/co detector that connects to Hubitat. It is about an inconspicuous multi-sensor (and notification) package that will be completely ignored until needed. Smoke detectors fit a critical but ignored niche for homes. But the number of people that are willing to buy SMART ones is low.
It boils down to a few things (IMO):
How many people are into home automation enough that they want those sensor systems? A fair number, or else the general industry would not be surviving.
Will they find out about them and purchase them? Tougher, because we all have seen these scenarios fail already.
Is that sustainable enough (with corporate greed) that limited market only replacing them every 10 years or so? Probably not. Not unless they can bring their costs down a lot or find regular other income, which boils down to a subscription for some services and/or selling the data the devices generate (if they send it back at all).
With the simple devices, is the extra cost per connected smoke detector vs a simple relay-based sensor that can take care of a whole system's notification worth it? Probably not.
