I thought I had things figured out--but maybe not.
I have a couple virtual switches that act as "state" variables for collections of settings.
E.g., "In the Office" On-> I'm working in the office for a while, Off->I'm done working there
Using a rule like "When 'In the Office' changes" do xxx, several actions would happen when it is turned "ON" and several other things when it is turned "OFF".
HOWEVER, if I have "In the Office"=ON and then I "arm" HSM, rules related to HSM Status will turn all kinds of things off and on. At this point, I want (need) to set "In the Office"==OFF WITHOUT the "When 'In the Office' changes" rule triggering and doing things that conflict with actions performed due to the HSM status change.
I thought the way to do this was to have the HSM rule "Pause" the "When 'In the Office' changes" rule, set "In the Office"=OFF, then "Resume" that rule.
However, my logs just seemed to show me a situation where my rule triggered anyway--right after the "Resume".
My concern is that either 1) Pause isn't stopping rules or, more likely, 2) There are asynchronous things happening and the rule can get triggered AFTER the "Resume" has taken effect if there's a slight delay in when the rule fires.
There really needs to be some fail-safe way to perform a (normally) "triggering action" without actually triggering anything. Without that type of capability, it's impossible to perform "reset state" type actions that don't generate all kinds of spurious and conflicting actions.
As for the "asynchronous events" scenario, a (terrible) workaround might be to delay the "Resume" a bit--but how long "a bit" needs to be is an unknown time period (depends how slow the RM is acting at any moment) and, if it is too long, it could easily stop the rule from firing for subsequent legitimate triggers.
That's why I'm seeking a "fail-safe" way to keep events from being triggered.
Thoughts? Thanks!
