Paused Rules still runs
Something recently happened with an update which allows Paused and Stopped rules to continue running. I have a front door alexa "front door opened" message that continues to run regardless if I have the rule paused or stopped.
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.535 AM[info](http://192.168.1.10/logs#)Action: END-IF
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.533 AM[info](http://192.168.1.10/logs#)~~Action: Exit Rule~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.531 AM[info](http://192.168.1.10/logs#)~~Action: parallelPlayAnnouncement('%device% %value%(Front Door closed)') on Office - Echo, Media Room - Echo, Kitchen - Echo, Master Bedroom - Echo~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.526 AM[info](http://192.168.1.10/logs#)Action: IF (Time Since Event: **contact(open)** on Front Door(0:00:01) exceeds 0:02:00(F) [FALSE]) THEN (skipping)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.419 AM[info](http://192.168.1.10/logs#)Action: Cancel Delayed Actions
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.385 AM[info](http://192.168.1.10/logs#)Action: Stop Repeating Actions
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.383 AM[info](http://192.168.1.10/logs#)Action: ELSE (do actions)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.381 AM[info](http://192.168.1.10/logs#)~~Action: END-REP~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.378 AM[info](http://192.168.1.10/logs#)~~Action: parallelPlayAnnouncement('%device% %value%(Front Door closed)') on Office - Echo, Media Room - Echo, Kitchen - Echo, Master Bedroom - Echo~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.373 AM[info](http://192.168.1.10/logs#)~~Action: Repeat every 0:05:00 (stoppable)~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.370 AM[info](http://192.168.1.10/logs#)Action: IF (Front Door contact open(F) [FALSE]) THEN (skipping)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.362 AM[info](http://192.168.1.10/logs#)Action: END-IF
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.359 AM[info](http://192.168.1.10/logs#)~~Action: Delay 0:02:30 (cancelable)~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.356 AM[info](http://192.168.1.10/logs#)~~Action: parallelPlayAnnouncement('%device% %value%(Front Door closed)') on Office - Echo, Media Room - Echo, Kitchen - Echo, Master Bedroom - Echo~~ (skipped)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.351 AM[info](http://192.168.1.10/logs#)Action: IF (Front Door contact open(F) [FALSE]) THEN (skipping)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.304 AM[info](http://192.168.1.10/logs#)Triggered: Front Door contact *changed*
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:17.133 AM[info](http://192.168.1.10/logs#)Event: Front Door contact closed
[dev:157](http://192.168.1.10/logs#)2024-05-21 10:49:17.024 AM[info](http://192.168.1.10/logs#)Front Door is closed
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:16.618 AM[info](http://192.168.1.10/logs#)Action: Delay 0:02:30 (cancelable)
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:16.322 AM[info](http://192.168.1.10/logs#)Action: parallelPlayAnnouncement('%device% %value%(Front Door open)') on Office - Echo, Media Room - Echo, Kitchen - Echo, Master Bedroom - Echo
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:16.317 AM[info](http://192.168.1.10/logs#)Action: IF (Front Door contact open(T) [TRUE]) THEN
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:16.270 AM[info](http://192.168.1.10/logs#)Triggered: Front Door contact *changed*
[app:403](http://192.168.1.10/logs#)2024-05-21 10:49:16.047 AM[info](http://192.168.1.10/logs#)Event: Front Door contact open
[dev:157](http://192.168.1.10/logs#)2024-05-21 10:49:15.966 AM[info](http://192.168.1.10/logs#)Front Door is open
[app:544](http://192.168.1.10/logs#)2024-05-21 10:49:04.526 AM[info](http://192.168.1.10/logs#)Event: Paused by **This Rule**
this used to never happen when i paused rules. now it seems pausing or stopping a rule has no effect for me.
You should mention what version you're on and what hub.
I just tried it on my C8 running the latest beta, and I get the following with an RM rule paused.
Although, I've never really looked at apps logs too much.
edit: ACTUALLY, it's NOT the latest beta, lol. It's the version previous.
C7 v 2.3.8.140
I do see the log for app pause at the 10:49:04 mark above. but clearly you see the rule start running when I opened the door at 10:49:15.
geez. someone delete this thread please. i was pausing the wrong rule. my mistake. no issues besides my own brain fog.
I missed the side and bottom bars, sorry.
In your logs, what is app 544 and what is app 403 -- which one is the rule that is supposed to be paused?
Posting a picture of the rule itself may be helpful too.
Hey, wait a minute.
How do you get those bars?
what are "bars" ?
The scrolling bars.
Forget it. I probably never snip anything that big.
oh, it is the PREFORMATTED TEXT icon. sixth one from the left.
