Pause Rules
Hello,
I would love to be able to pause a rule
Use case: Create a Simple Lighting rule, then decide to create the same rule in RM to compare. Need to be able to pause a rule rather than delete it
Thanks in advance
Rick
A simple workaround,for now, is to add a restriction, like mode or time of day.
To add to ogiewan’s suggestion, you could make a mode called Pause that has no triggers. That way any rule set to that mode wouldn’t trigger until you removed the mode restriction.
