Past Logs - The device name in the Past logs does not change after renaming the Device Name
I am on Platform version 2.3.9.166
The issue I am having is that device name in the Past logs does not change after renaming the Device Name
Past Logs will use the oldest available device name in the logs (until they are gradually purged out in accordance with the size-based limit, so you'll see the new name eventually, depending on how fast your logs fill up -- or if you purge them yourself). What you are describing sounds consistent with that -- i.e., normal.
See: Logs | Hubitat Documentation
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
