Parse Map
I have a map of the form:
[1:[var:1234, item:abcd], 2:[var:5678, item:efgh]]
How do I parse the individual items in an app? Can't seem to figure it out myself.
Something like this?
map = [1:[var:1234, item:abcd], 2:[var:5678, item:efgh]]
map.each{
    thisIterationNumber = it.key
    thisVar = it.value.var
    thisItem = it.value.item
    // Do your stuff
This is a map of maps. Let's assume the following:
Map outerMap = [1:[var:1234, item:abcd], 2:[var:5678, item:efgh]]
outerMap[1] = [var:1234, item:abcd]
outerMap[2] = [var:5678, item:efgh]
Now, it might be:
outerMap['1'] = [var:1234, item:abcd]
outerMap['2'] = [var:5678, item:efgh]
Depending on whether it's an Integer 1 or the string representation "1".
With Groovy, you can also iterate with the each or eachWithIndex closures, like this:
outerMap.each{ k,v -> doSomething(k,v) }
which with this example would do the following:
doSomething(1234, abcd)
doSomething(5678, efgh)
That worked. One more question, in the each iteration, is there a way to extract the iteration number? Ie the 1 or 2, etc. What I want to do is find the highest map used.
I edited my example above.
The it.key statement will contain the key of the map iteration.
I tried that, but the β€˜it’ gives me the entire map entry for a given number. I need to extract just the array position.
1={var=1234, item=abcd} is what I get for each array position
Sorry. Brain fart moment. I again edited my answer above.
The correct usage is it.key.
Instead of each{} use eachWithIndex{}.
Example:
each{runMethod(it)}
eachWithIndex(runMethod(it, index)}
each{} has it as the implicit name for the current iteration object, eachWithIndex{} uses it and index
Alternatively, you can specify names:
eachWithIndex{ myThing, myIndex -> doStuff(myThing, myIndex)}
