Parking sensor green/red light
Unfortunately the light turns on outside of the conditions when the beam is tripped. I’m this case the test contact remains closed, if the beam is tripped the light turns red and should not come on. I am still trying to iron out this rule.
Would you post the latest copy of your rule and any logs that show this behavior?
Sorry for the delay. I travel for work and haven't been available to mess with this. I have this rule working, but I can't seem to get it to turn red with the LED strip I use. The test contact represents the garage door, the LED turns green, but when the infrared sensor is blocked, the light turns yellowish color. In device settings, I can get the strip to turn red, but it will not turn red in a simple rule or this Rule machine rule. The only thing I can see happening is the HUE is changing and shouldn't be during the color shift. I have tried different drivers. This is a Zigbee RGBW 12V LED strip with a Zigbee RGBW GLEDOPTO device hooked up.
EDIT: I ended up doing a custom color entry for RED #ff0000 and it works. This rule now works as needed. Thank you for all the help.
