Hi everyone -
I developed a Parent/Child TCP with Generic Component Switch.
This is for a multi-relay device with 8 ports, that can be turned on/off manually from the board, or remotely by Hubitat (app). So the driver has to monitor (parse) the status of the relays and changes, and communicate back and forth.
Creation of child devices - perfect! Ok -
I first did it with Virtual Switch - had an issue with sending the commands to the child device. But worked perfect the fact that I had status on/off in each child device.
So I changed to Generic Component Switch. For each on/off call to the child, I know have an "cd.updateDataValue("powerstatus","on")" (or off), to change a data attribute in the child.
BUT - when I install these Relays in the dashboard, I cannot assign any attribute or feedback of the current status of the relay which should be from the powerstatus data in the child device.
As it does not show as a status attribute for the device settings.
Also I believe that situation would affect the Alexa integration for integration.
Any ideas on how to approach and solve?
I will paste the code of the driver here - (some has comments in portuguese - sorry)
- Hubitat - TCP Driver by TRATO - BETA OK
- Copyright 2024 VH
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "TCP Device Driver v3 - by TRATO", namespace: "TRATO", author: "TRATO", vid: "generic-contact") {
// capability "AudioVolume"
capability "Configuration"
capability "Initialize"
// capability "MusicPlayer"
capability "Refresh"
// capability "SpeechSynthesis"
capability "Switch"
//attribute "status", "string"
import groovy.json.JsonSlurper
import groovy.transform.Field
command "buscainputcount"
command "createchilds"
preferences {
input "device_IP_address", "text", title: "IP Address of Device", required: true, defaultValue: "192.168.0.0"
input "device_port", "number", title: "IP Port of Device", required: true, defaultValue: 502
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: false
input name: "powerstatus", type: "string", title: "Power Status"
input 'logInfo', 'bool', title: 'Show Info Logs?', required: false, defaultValue: true
input 'logWarn', 'bool', title: 'Show Warning Logs?', required: false, defaultValue: true
input 'logDebug', 'bool', title: 'Show Debug Logs?', description: 'Only leave on when required', required: false, defaultValue: true
input 'logTrace', 'bool', title: 'Show Detailed Logs?', description: 'Only leave on when required', required: false, defaultValue: true
attribute "powerstatus", "string"
@Field static String partialMessage = ''
@Field static Integer checkInterval = 600
def installed() {
logTrace('installed()')
//buscainputcount()
updated()
def novaprimeira = ""
def oldprimeira = ""
runIn(1800, logsOff)
def uninstalled() {
logTrace('uninstalled()')
unschedule()
interfaces.rawSocket.close()
def updated() {
logTrace('updated()')
initialize()
refresh()
def configure() {
logTrace('configure()')
unschedule()
def initialize() {
logTrace('initialize()')
unschedule()
interfaces.rawSocket.close();
state.clear()
partialMessage = '';
if (!device_IP_address) {
logError 'IP do Device not configured'
return
if (!device_port) {
logError 'Porta do Device não configurada.'
return
//Llama la busca de count de inputs+outputs
buscainputcount()
try {
logTrace("tentando conexão com o device no ${device_IP_address}...na porta ${device_port}");
int i = 502
interfaces.rawSocket.connect(device_IP_address, (int) device_port);
state.lastMessageReceivedAt = now();
//runIn(checkInterval, "connectionCheck");
//refresh(); // se estava offline, preciso fazer um refresh
catch (e) {
logError( "${device_IP_address} initialize error: ${e.message}" )
//runIn(60, "initialize");
createchilds()
def createchilds() {
String thisId = device.id
log.info "info thisid " + thisId
def cd = getChildDevice("${thisId}-Switch")
if (!cd) {
log.info "inputcount = " + state.inputcount
for(int i = 1; i<=state.inputcount; i++) {
cd = addChildDevice("hubitat", "Generic Component Switch", "${thisId}-Switch-" + Integer.toString(i), [name: "${device.displayName} Switch-" + Integer.toString(i) , isComponent: true])
log.info "added switch # " + i + " from " + state.inputcount
def buscainputcount(){
try {
httpGet("http://" + settings.device_IP_address + "/relay_cgi_load.cgi") { resp ->
if (resp.success) {
logDebug "Busquei o numero de relays(): " + resp.data
//logDebug "initialize(): Response[3] = " + (resp.data as String)[3]
//Verifica a quantidade de Relays que tem a placa, usando o primeiro digito do 3 caracter do response. (2 ou 4 ou 8 ou 1 ou 3)
inputCountV = (resp.data as String)[3] as int
if (inputCountV == 4) {
inputCount = 4
if (inputCountV == 8) {
inputCount = 8
if (inputCountV == 1) {
inputCount = 16
if (inputCountV == 3) {
inputCount = 32
state.inputcount = inputCount // deixar o numero de relays na memoria
else {
if (resp.data) logDebug "initialize(): Falha para obter o # de relays ${resp.data}"
} catch (Exception e) {
log.warn "initialize(): Call failed: ${e.message}"
def ipmolsmart = settings.device_IP_address
state.ipaddress = settings.device_IP_address
def refresh() {
logTrace('refresh()')
def msg = "test"
sendCommand(msg)
//Feedback e o tratamento
def fetchChild(String type, String name){
def cd = getChildDevice("${thisId}-${type}${name}")
if (!cd) {
cd = addChildDevice("hubitat", "Generic Component ${type}", "${thisId}-${type}${name}", [name: "${name}", isComponent: true])
cd.parse([[name:"switch", value:"off", descriptionText:"set initial switch value"]]) //TEST!!
return cd
def parse(msg) {
state.lastMessageReceived = new Date(now()).toString();
def oldmessage = state.lastmessage
//log.info "oldmessage = " + oldmessage
def oldprimeira = state.primeira
//log.info "oldprimeira = " + oldprimeira
state.lastprimeira = state.primeira
def newmsg = hubitat.helper.HexUtils.hexStringToByteArray(msg) //na Mol, o resultado vem em HEX, então preciso converter para Array
def newmsg2 = new String(newmsg) // Array para String
state.lastmessage = newmsg2
//(Doing a search with "Contain" to see the board model, and qty of relays inside of the model MolSmart 4/8/16/32 relays).
if (newmsg2.contains("32")) {
state.primeira = newmsg2[0..31]
state.channels = 32
novaprimeira = newmsg2[0..31]
log.debug "Placa de 32"
if (newmsg2.contains("16")) {
state.primeira = newmsg2[0..15]
state.channels = 16
novaprimeira = newmsg2[0..15]
log.debug "Placa de 16"
if (newmsg2.contains("8")) {
state.primeira = newmsg2[0..7]
state.channels = 8
novaprimeira = newmsg2[0..7]
log.debug "Placa de 8"
if (newmsg2.contains("4")) {
state.primeira = newmsg2[0..3]
state.channels = 4
novaprimeira = newmsg2[0..3]
log.debug "Placa de 4"
//compare last parse result with current, and if different, compare changes.
if ((novaprimeira)&&(oldprimeira)) { //if not empty in first run
if (novaprimeira.compareToIgnoreCase(oldprimeira) == 0){
log.info "no changes in relays"
else{
log.info "Yes, changes made"
for(int f = 1; f <state.inputcount; f++) {
def valprimeira = state.primeira[f]
def valold = oldprimeira[f]
def diferenca = valold.compareToIgnoreCase(valprimeira)
switch(diferenca) {
case 0:
log.info "no changes in ch#" + (f+1) ;
break
case -1: // -1 is when light was turned ON
if (state.update == 1){ //no hace nada porque fue el switch
log.info "on changes in ch#" + (f+1) ;
else {
//cd.deviceid
//fetchid
//change status switch to ON
break
case 1: // 1 is when light was turned OFF
log.info "off changes in ch#" + (f+1) ;
break
default:
log.info "changes in ch#" + (f+1) + " with dif " + diferenca;
break
state.update = 0
for(int f = 0; f <state.inputcount; f++) {
val = state.primeira[f]
//log.info "posição f= " + f + " valor state = " + val
log.info "status do update = " + state.update
////Commands
def on()
logDebug("Master Power ON()")
def msg = "1X"
sendCommand(msg)
def off()
logDebug("Master Power OFF()")
def msg = "2X"
sendCommand(msg)
private sendCommand(s) {
logDebug("sendCommand ${s}")
interfaces.rawSocket.sendMessage(s)
//// Connections Checks ////
def connectionCheck() {
def now = now();
if ( now - state.lastMessageReceivedAt > (checkInterval * 1000)) {
logError("sem mensagens desde ${(now - state.lastMessageReceivedAt)/60000} minutos, reconectando ...");
initialize();
else {
logDebug("connectionCheck ok");
def socketStatus(String message) {
if (message == "receive error: String index out of range: -1") {
// This is some error condition that repeats every 15ms.
logError( "socketStatus: ${message}");
logError( "Closing connection to device" );
else if (message != "receive error: Read timed out") {
// Component Child
void componentRefresh(cd){
if (logEnable) log.info "received refresh request from ${cd.displayName}"
refresh()
def componentOn(cd){
if (logEnable) log.info "received on request from ${cd.displayName}"
on(cd)
cd.updateDataValue("Power","On")
cd.updateDataValue("switch","on")
void componentOff(cd){
if (logEnable) log.info "received off request from ${cd.displayName}"
off(cd)
cd.updateDataValue("Power","Off")
////// Driver Commands /////////
//SEND ON COMMAND IN CHILD BUTTON
void on(cd) {
if (logEnable) log.debug "Turn device ON "
sendEvent(name: "switch", value: "on", isStateChange: true)
ipdomodulo = state.ipaddress
lengthvar = (cd.deviceNetworkId.length())
int relay = 0
if (lengthvar < 13) {
def numervalue1 = (cd.deviceNetworkId as String)[11]
def valor = ""
valor = numervalue1 as Integer
relay = valor
else
def numervalue2 = (cd.deviceNetworkId as String)[12]
def valor = ""
valor = numervalue2 as Integer
relay = valor
def stringrelay = relay
def comando = "1" + stringrelay
interfaces.rawSocket.sendMessage(comando)
log.info "Foi Ligado o Relay " + relay + " via TCP " + comando
sendEvent(name: "power", value: "on")
state.update = 1 //variable to control update with board on parse
//SEND OFF COMMAND IN CHILD BUTTON
void off(cd) {
if (logEnable) log.debug "Turn device OFF"
sendEvent(name: "switch", value: "off", isStateChange: true)
int relay = 0
def valor = ""
relay = valor
else
def valor = ""
relay = valor
def comando = "2" + stringrelay
log.info "Foi Desligado o Relay " + relay + " via TCP " + comando
////////LOGGING
logs.....
private processEvent( Variable, Value ) {
if ( state."${ Variable }" != Value ) {
state."${ Variable }" = Value
logDebug( "Event: ${ Variable } = ${ Value }" )
sendEvent( name: "${ Variable }", value: Value, isStateChanged: true )
def logsOff() {
log.warn 'logging disabled...'
device.updateSetting('logInfo', [value:'false', type:'bool'])
device.updateSetting('logWarn', [value:'false', type:'bool'])
device.updateSetting('logDebug', [value:'false', type:'bool'])
device.updateSetting('logTrace', [value:'false', type:'bool'])
void logDebug(String msg) {
if ((Boolean)settings.logDebug != false) {
log.debug "${drvThis}: ${msg}"
void logInfo(String msg) {
if ((Boolean)settings.logInfo != false) {
log.info "${drvThis}: ${msg}"
void logTrace(String msg) {
if ((Boolean)settings.logTrace != false) {
log.trace "${drvThis}: ${msg}"
void logWarn(String msg, boolean force = false) {
if (force || (Boolean)settings.logWarn != false) {
log.warn "${drvThis}: ${msg}"
void logError(String msg) {
log.error "${drvThis}: ${msg}"
