I thought that you had to push two buttons at once to do the reset, but the instructions on the RGBgenie site say to just hold the ON button (second from bottom).
The instructions on their site also say if it blinks when you push a button, it is supposedly paired.
There's a driver issue with this device. I had to use a different device driver (with an incorrect number of buttons) in order to get access to the buttons that do exist.
Replying to myself to document this, but this hopefully will help else having trouble with this in the future.
I could not get this to pair again (was previously paired with this hub) no matter what I did. Apparently, I found a way to factory reset it. Hold the "on" button until it blinks, then press the "on" button 5 times very rapidly.
Start pairing mode on the hub. Hold the "on" button on the remote until it blinks, then short press the "off" button. It nearly instantly was found by the hub. Just doing the pairing procedure did not work, you had to do a reset.
Thank you for posting that. If any of our remotes have been part of a network before. They will need to be reset as you described. Not sure why it fell off the network.
It seems to happen if the battery goes dead, and you don't notice for a while. If you catch it right away and put a new battery in, it doesn't need this reset. I suspect that is what happened to Stephen too.
Hmmm... that should not happen. It should retain the settings. Pop the battery out and see if it happens again. If so, I'll send you another. Just pm me.
Like I said, if I catch it right away, like within a day or two, it re-pairs fine. It just seems to have trouble if you wait like a couple weeks or more.
I am not concerned about it, now that I know how to do the reset I am fine. Part of why I posted is because I couldn't find my instruction manual, and there are zero manuals on the 'net including on your site for this device.
Maybe try to pull the battery from the 5121 for a few seconds before trying the the reset? Or with your hub shut down (settings tab, shutdown), and unplugged plug from the wall?
I’ve been trying to reset one of my ZB-5122 remotes and I can’t get the factory reset to work. The factory reset instructions that came with the 5122 look similar to the 5121.
How fast is “very rapidly”? I hold the on and off buttons for a few seconds and then the LED light turns on. I’ve tried tapping the on button 5 times kinda fast, fast, very fast and extremely fast but I can’t get it to do the factory reset.
I had an idea right after posting which worked so I’m documenting it here.
I had been trying to factory reset because I changed my zigbee channel (now using 26) and the remote stopped working. I hadn’t waited a full 24 hours but I was skeptical that the remote would figure out the channel change. I thought I needed to factory reset it and re-pair it to get on the new channel.
Turns out I only needed to pull out the battery and put it back it. The remote immediately started working on the new channel.
