Hello,
New Hubitat user here. Moving from Wink. I have paired two switches
GE zw4005
Leviton model unknown.
I am unable to get the switches to actually change state from the commands menu.
any suggestions?
Hello,
GE zw4005
any suggestions?
What driver have they linked with, its near the bottom of the detail page
For some devices, even if they are correctly discovered, you need to manually assign the correct driver to be able to make it work correctly.
As Mark mentions, in the device screen, check the initially assigned driver and change to one that works with your device. Save and configure it.
Thanks for your input, What worked was for me to exclude them again and the include. This time thy work with out having to change driver.
