Is there a way to change the default tile for Own Tracks? It shows up as on/off in the Hubitat Home page. I have the default current state under preferences set to presence, but it still shows as "off."
since you're on the new dashboard (i'm not very familiar with them yet, as I'm sticking with the legacy Dashboards) if you click the padlock in the lower right of the screen enter edit mode, click the gear on the top right corner of you switch you should be able to change the type from switch to Presence sensor. Once you're done editing click the padlock again to save and lock I hope this helps
