Some how I have managed to create a device that when opened. It gives a blank screen and a never ending spinning blue circle in top right corner. Is there a way to remove this device that I cannot access?
In the top right of the device list page there is an option to display the device enable / disable checkbox. Turn this on, go to your device in the list, tick the checkbox to disable it. Click on the device to open the Device Edit page and you should now be able to remove it.
That worked fine. Thank you.
No worries. What kind of device was it?
Was trying to get the Simple Kitchen Timer app to work. Ended up with a blank Timer device. When I uninstalled the app. Not sure where I went wrong
Probably work posting on the thread for the driver as well. But maybe try again first and get some log info if you can
