Organizing Rules
Greetings everyone,
I am new here I’m moving from home control assistant which I have used for well over 17 years and simply love the way that they organize everything over to Hubitat which so far leaves me bewildered.
I want to organize my rules by room and then by time they happen this way I can logically see which roles happen in which roles in what order.
So far the rules are displayed in the order that I enter them which for the life of me I don’t understand seems way counterproductive.
Any suggestions?
I think there alphabetical
They should be alphabetical. If you want to "group" by room, I would use some sort of naming convention, like putting the room name first whenever you name the rule.
Here is an example of the sorting I mean (ignore the fact that I start all my rule names with then name of the app...I like it, but many people don't--point is, they're all alphabetical and I didn't create them in this order):
screenshot of rule/app list
I guess this part isn't really a question, but I'm still confused. :slight_smile: The order you create a rule (or any app) in doesn't matter; if they both respond to the same event, they'll happen more or less at the same time (or at least nearly so and not in a guratanteed order). If you're running one rule from another, e.g., with Run Rule Actions, and are this controlling the order of execution in this ir a similar manner, then...nevermind! Just wanted to make sure there wasn't any confusion here.
Thanks everyone didn't consider renaming them.
Okay follow up question
How do you rename rules?
Open the Rule (click on the current name). Rename it. And then click Done.
