Orbit Hose Faucet Timer (27087) Pairing Issue
I just got an Orbit Has Faucet Timer Model 27087. I cannot get it to pair. It is listed on the Hubitat compatible devices list and I have followed the instructions for pairing. I have even followed the instructions to factory reset and that doesn't help either. Has anybody paired one of these things? If so, any pointers?
I just paired one of these after seeing your message. Paired fine. Going to un-pair it, and pair it again.
Edit: It reset perfectly when it was unpaired. And paired back again. Here are the logs:
hosetimer
I would recommend trying to pair it within 10-15 ft of the Hubitat during initial pairing.
I figured it out…. My main hub uses zigbee channel 26 and the device will not pair to that hub. My secondary hub uses zigbee channel 25 and it paired fine. I’m thinking that the device won’t use 26. Nevertheless it is paired and operational.
Thanks for your help.
