Openweathermap issue
New user. Still developing dashboards.. Tried adding weather. Unsure of where I went wrong. Hopefully pictures will help
you help me...
The first thing you need to do is hide your API key in the 4th screenshot.
You don't want people duplicating this.
What did you select in your dashboard. Temp, Humidity etc?
Thanks for trying to help. 1. I cannot see how to delete the picture from my post to then add an edited picture. 2. I don't know what screen to go to to answer your question (dashboard, temp, humidity?).
I don't use EZ Dashboards (which I believe you are using) but on a classic dashboard you select the device you want to display on the dashboard and then you select which template/attribute you want to display. Temperature, Illuminance etc.
What template/attribute are you selecting for Openweather?
BTW if you edit your original post you can delete the screenshot that displays your API key.
Click on the image symbol
