I am new to Hubitat, and I'm in the process of configuring everything (so far so good). I am working on adding an OpenWeatherMap (built in) virtual device, and it's returning this error in the logs:
"OpenWeatherMap - getWeather() execption java.net.UnknownHostException: api.openweathermap.org: Temporary failure in name resolution"
I tested the API Key directly on the browser with OWM URI and it's confirmed working, as I get the JSON with the appropriate data. However the OpenWeatherMap virtual device is returning that error above; any idea how to fix this, please advice. Thanks.
@csteele - UPDATE:
You're a genius! I went back into the HE hub and added another DNS lookup source and it worked. Glad that's a simple fix. Thanks again.
I faced a similar problem. I switched from DHCP to Static IP but I didn't enter anything in the DNS field. But DNS seems to continue to work until a few weeks later (cached?). So I add a DNS entry to the Static IP page and DNS is working again.
