Not planning on adding these as to the master file. If you need them you can add them to your copy.
I am a little confused on the change you just made. In the screen shot below the forecast is light rain, Why does it say broken clouds. This is with the switch off. Should the tiles not say Light rain? When I turn the switch on, it matches. Also, I think he was asking for the 3day forecast to show the forecast only and the My tile to show current conditions. Right now they both show the same.
Thank you Matthew.
However after installing V0.5.6 I continue to always see the current condition text, "broken clouds", on the three day tile with the Condition Icon: On=Current or Off=Forecast switch set On or Off, when is should say "light rain".
I notice that @Jasonrwise77 states it's working. Am I using the wrong setting?
This is the open weather city link
I believe the icon works as intended, however the 'condition text' always is the 'current condition'. I will try to sync that up to show the text for 'forecast condition' when that is selected. Hopefully later today.
Thanks.
While the code is open, kindly consider changing the setting's text
To: 3-Day Current Day's Icon and Text: On=Current or Off=Forecast
The setting is used for both the MyTile and the ThreeDayForecastTiles. I'll see what I can do.
That explains my confusion about what I'm seeing.
Perhaps two settings for Current/Forecast, one for MyTile and one for 3-Day, makes more sense?
UPDATED V0.5.7 06/12/2022
- Both MyTile and the Three day Forecast Tile now use the Icon and Text selected in the 'Condition Icon/Text for current day on MyTile & Three Day Forecast Tile' option.
I would agree that having 2 settings does make a little more sense. I would love the ability to have the mytile show current and the 3day forecast show todays forecast.
I am sorry to bug you, but something is still not right or I might be mistaken. Now when I turn the switch on or off, It is changing the condition_text variable to match the forecast. So when I have switch off it is showing moderate rain, but when I turn it on it changes the condition text to match the forecast. Was that the intended result?
The intent: When the switch is on both the Icon and the text will show the 'Current' conditions. When the switch is off both the Icon and the Text will show the 'Forecast' conditions. This pertains to both the MyTile and the ThreeDayForecastTile.
For both tiles you either get the current day's 'Current' condition as reported by OWM, or you get the current day's 'Forecast' condition as reported by OWM. At this time I do not plan on adding a second option to allow each tile to be set independently.
Yes, the tiles are all good, but the variable outside of the tile is changing when you put the swithc to on or off. For example right now
Current condition is scattered clouds
Forcast is light rain
if I set the switch to off
Current conditon is light rain
If this is the intened affect that is fine, I just need to know so I can do my automations correctly.
The text I highlighted is what is changing.
I did not write it to preserve both attributes, so yes, if you select Off (for Forecast) the 'Current Condition' will reflect the forecast that you selected.
Thank you very much, I really appreciate all the help.
Found a minor error on line 493
}else if(twb < 56.25) {
should be
}else if(twb < 78.75) {
This has been corrected in the code. Re-import the code or do a Repair in HPM. The version number was not updated.
Thanks @arnb
I have been getting an error since last night.
2022-07-25 09:18:21.134 pm errorjava.lang.IllegalArgumentException: The JSON input text should neither be null nor empty. on line 1296 (method pollOWMHandler)
From the detailed logging:
OpenWeatherMap Data: [current:[sunrise:1658744216, temp:79.88, visibility:10000, uvi:0, pressure:1016, clouds:100, feels_like:79.88, wind_gust:15.64, dt:1658798297, wind_deg:245, dew_point:67.06, sunset:1658795200, weather:[[icon:04n, description:overcast clouds, main:Clouds, id:804]], humidity:65, wind_speed:5.82], timezone:America/New_York, timezone_offset:-14400, daily:[[moonset:1658788620, rain:0.24, sunrise:1658744216, temp:[min:70.86, max:94.05, eve:82.56, night:77.7, day:93.4, morn:71.82], moon_phase:0.91, uvi:9.54, moonrise:1658733420, pressure:1017, clouds:75, feels_like:[eve:85.46, night:78.66, day:96.58, morn:72.97], wind_gust:25.14, dt:1658768400, pop:0.92, wind_deg:219, dew_point:66.69, sunset:1658795200, weather:[[icon:10d, description:light rain, main:Rain, id:500]], humidity:41, wind_speed:12.01], [moonset:1658878080, rain:12.83, sunrise:1658830662, temp:[min:71.92, max:94.05, eve:76.17, night:73.04, day:82.44, morn:72.21], moon_phase:0.94, uvi:8.29, moonrise:1658822640, pressure:1018, clouds:98, feels_like:[eve:77.58, night:74.55, day:86.79, morn:73.69], wind_gust:21.83, dt:1658854800, pop:1, wind_deg:224, dew_point:70.84, sunset:1658881556, weather:[[icon:10d, description:moderate rain, main:Rain, id:501]], humidity:68, wind_speed:11.83], [moonset:1658967120, rain:3.09, sunrise:1658917109, temp:[min:71.85, max:94.01, eve:78.42, night:75.87, day:90.34, morn:72.59], moon_phase:0.97, uvi:7.64, moonrise:1658912220, pressure:1016, clouds:88, feels_like:[eve:79.45, night:77.05, day:95.23, morn:74.01], wind_gust:22.03, dt:1658941200, pop:0.96, wind_deg:313, dew_point:68.99, sunset:1658967909, weather:[[icon:10d, description:moderate rain, main:Rain, id:501]], humidity:50, wind_speed:11.74], [moonset:1659055860, rain:1.84, sunrise:1659003556, temp:[min:71.73, max:97.05, eve:78.48, night:75.7, day:95.43, morn:72.91], moon_phase:0, uvi:9.95, moonrise:1659002100, pressure:1015, clouds:48, feels_like:[eve:79.79, night:76.64, day:100.36, morn:74.14], wind_gust:21.7, dt:1659027600, pop:0.72, wind_deg:270, dew_point:67.93, sunset:1659054262, weather:[[icon:10d, description:light rain, main:Rain, id:500]], humidity:41, wind_speed:8.05], [moonset:1659144300, rain:4.75, sunrise:1659090003, temp:[min:72.14, max:98.96, eve:81.23, night:76.24, day:98.96, morn:77.74], moon_phase:0.03, uvi:9.57, moonrise:1659092040, pressure:1013, clouds:28, feels_like:[eve:85.21, night:77.79, day:101.68, morn:78.78], wind_gust:19.33, dt:1659114000, pop:0.65, wind_deg:254, dew_point:64.44, sunset:1659140613, weather:[[icon:10d, description:moderate rain, main:Rain, id:501]], humidity:32, wind_speed:10.92], [moonset:1659232440, rain:6.32, sunrise:1659176450, temp:[min:70.47, max:94.14, eve:77.92, night:70.47, day:94.14, morn:74.86], moon_phase:0.06, uvi:0.75, moonrise:1659182100, pressure:1019, clouds:25, feels_like:[eve:79.12, night:71.73, day:98.44, morn:76.05], wind_gust:10.92, dt:1659200400, pop:1, wind_deg:22, dew_point:68.04, sunset:1659226963, weather:[[icon:10d, description:moderate rain, main:Rain, id:501]], humidity:42, wind_speed:5.64], [moonset:1659320460, rain:15.72, sunrise:1659262898, temp:[min:69.21, max:86.09, eve:74.5, night:70.16, day:83.59, morn:72.09], moon_phase:0.09, uvi:1, moonrise:1659272100, pressure:1022, clouds:100, feels_like:[eve:75.97, night:71.44, day:88.16, morn:73.45], wind_gust:17.9, dt:1659286800, pop:1, wind_deg:215, dew_point:70.56, sunset:1659313311, weather:[[icon:10d, description:moderate rain, main:Rain, id:501]], humidity:65, wind_speed:7], [moonset:1659408360, rain:1.95, sunrise:1659349346, temp:[min:69.35, max:89.28, eve:80.51, night:74.52, day:89.28, morn:71.94], moon_phase:0.12, uvi:1, moonrise:1659362100, pressure:1019, clouds:92, feels_like:[eve:83.64, night:75.61, day:92.44, morn:73.2], wind_gust:14.7, dt:1659373200, pop:0.99, wind_deg:249, dew_point:66.97, sunset:1659399657, weather:[[icon:10d, description:light rain, main:Rain, id:500]], humidity:48, wind_speed:8.43]], lon:-78.859, lat:36.1321]
Update: I tried to repair in HPM, it had a weird error about the manifest. I removed it entirely and re-created it and now it is updating the time again (It still is reporting that it isn't getting sunrise/sunset data, but no errors )
I'm getting the error now too. I don't use HPM. What did you remove and recreate - the device with the driver attached or the driver code?
[UPDATED] V0.5.8 07/26/2022
- Improved Fallback to hub location defaults and estimates for Sunrise-Sunset.org poll failure.
