- OpenSprinkler Station Driver
- Copyright 2018 Ben Rimmasch
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition(name: "OpenSprinkler Station", namespace: "codahq-hubitat", author: "Ben Rimmasch") {
capability "Refresh"
capability "Valve"
capability "Actuator"
capability "Switch"
capability "Sensor"
command "open", [[name: "Delay Open", type: "NUMBER", description: "Enter a value in seconds to delay before opening"], [name: "Duration", type: "NUMBER", description: "Enter a value in seconds to run before closing"]]
preferences {
input name: "descriptionTextEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: false
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: false
input name: "traceLogEnable", type: "bool", title: "Enable trace logging", defaultValue: false
input name: "defaultRuntime", type: "number", range: 1..64800, title: "Default Duration", description: "Default duration in seconds this station will run if no duration is specified", defaultValue: 60, required: true
input name: "runOnceRuntime", type: "number", range: 1..64800, title: "Run-once Duration", description: "Duration in seconds this station will run when the system runs a run-once program", defaultValue: 60, required: true
def installed() {
initialize()
def updated() {
initialize()
def initialize() {
sendEvent(name: "switch", value: "on")
sendEvent(name: "valve", value: "closed")
def refresh() {
parent.refresh()
def open(BigDecimal delay = null, BigDecimal duration = null) {
logDebug "open(${delay},${duration})"
unschedule()
if (delay != null) {
logInfo "Opening ${device.label} in ${delay} seconds"
runIn(delay.toInteger(), callbackOpen, [overwrite: false, data: [duration: duration]])
return
else {
logTrace "duration ${duration}"
sendEvent([name: "valve", value: "open", isStateChange: true])
def runTime = duration == null ? defaultRuntime.toInteger() : duration.toInteger()
logInfo "Opening station ${device.label} for ${runTime} seconds"
runIn(runTime + 5, refresh, [overwrite: false])
parent.api(parent.getSTATION_RUN(), [sid: stationIndex, duration: runTime])
def callbackOpen(data) {
logDebug "callbackOpen($data)"
open(null, data.duration)
def close() {
logDebug "close()"
unschedule()
logInfo "Closing station ${device.label}"
sendEvent([name: "valve", value: "closed", isStateChange: true])
parent.api(parent.getSTATION_OFF(), [sid: stationIndex])
def duration() {
logTrace "duration() ${runOnceRuntime}"
return runOnceRuntime as Integer
def off() {
//logDebug "off()"
//unschedule()
//close()
//not implemented
def on() {
//logDebug "on()"
//not implemented
private getStationIndex() {
return new String(device.deviceNetworkId).tokenize('-')[1]
private logInfo(msg) {
if (descriptionTextEnable) log.info msg
def logDebug(msg) {
if (logEnable) log.debug msg
def logTrace(msg) {
if (traceLogEnable) log.trace msg
