Open Weather not working on second hub
Hello! I can't get Open Weather to show my local weather. I have a valid API key that is setup and working on another hub. I used that same key to setup my new hub Open Weather.
The logs show the following:
penWeatherMap - getWeather() execption groovyx.net.http.HttpResponseException: status code: 404, reason phrase: Not Found
I have the same zip code in that works fine on my first hub. Suggestions please?
You might want to redact the API key thatโ€™s visible in the screenshot.
Did you make sure the API Key Version was correct?
