Open Meteo API-Driven air quality sensor
One more (sorry for the spam) - using the same open meteo API as my UV/ illuminance sensor, and my temperature and humidity sensor, I also created an air quality sensor using the same API.
Hope this is of use to someone
 *  Air Quality Sensor (Open-Meteo)
 *  Hubitat driver that reports current air quality data from Open-Meteo's Air
 *  Quality API for the hub's configured latitude and longitude.
 *  Author: Jon Wallace
 *  Copyright 2026 Jon Wallace
 *  License: MIT
 *  Notes:
 *  - Uses the United States AQI by default.
 *  - Pollutant concentrations are reported in ug/m^3 where provided by
 *    Open-Meteo.
 *  - Requires the hub location coordinates to be configured in Hubitat.
metadata {
  definition (
    name: "Air Quality Sensor (Open-Meteo)",
    namespace: "jonw",
    author: "Jon Wallace"
    capability "AirQuality"
    capability "Sensor"
    capability "Refresh"
    attribute "usAqi", "number"
    attribute "aqiCategory", "string"
    attribute "pm25", "number"
    attribute "pm10", "number"
    attribute "ozone", "number"
    attribute "nitrogenDioxide", "number"
    attribute "sulphurDioxide", "number"
    attribute "carbonMonoxide", "number"
    attribute "lastUpdated", "string"
  preferences {
    def lat = location?.latitude
    def lon = location?.longitude
    def hubLocationDescription = (lat != null && lon != null)
      ? "Using hub coordinates: ${lat}, ${lon}"
      : "Hub coordinates are not configured. Set the hub location in Hubitat before this driver can retrieve air quality data."
    input name: "hubLocationStatus", type: "paragraph", title: hubLocationDescription, displayDuringSetup: true
    input name: "updateFrequency", type: "number", title: "Auto-refresh interval (minutes)", description: "How often the driver refreshes air quality data.", defaultValue: 60, range: "1..1440"
    input name: "minAqiChange", type: "number", title: "Minimum AQI change to report", description: "Suppresses US AQI events until the change is at least this amount. Use 0 to report every refresh.", defaultValue: 1, range: "0..500"
    input name: "logEnable", type: "bool", title: "Enable debug logging", description: "Log API requests and update decisions.", defaultValue: false
// ===== Lifecycle =====
def installed() {
  log.info "Installed Open-Meteo Air Quality Sensor"
  initialize()
def updated() {
  log.info "Updated settings"
  initialize()
def initialize() {
  unschedule()
  scheduleAutoRefresh()
  refreshAirQualityData()
// ===== Commands =====
def refresh() {
def scheduleAutoRefresh() {
  def minutes = settings?.updateFrequency != null ? settings.updateFrequency as Integer : 60
  minutes = Math.max(1, Math.min(1440, minutes))
  if (logEnable) log.debug "Scheduling auto-refresh every ${minutes} minutes"
  if (minutes == 60) {
    runEvery1Hour(refreshAirQualityData)
  } else {
    schedule("0 */${minutes} * ? * *", refreshAirQualityData)
def refreshAirQualityData() {
  def coords = getHubCoordinates()
  if (!coords) {
    log.error "Hub coordinates are not configured. Set the hub location in Hubitat before retrieving air quality data."
    return
  def lat = coords.lat
  def lon = coords.lon
  def currentFields = "us_aqi,pm2_5,pm10,ozone,nitrogen_dioxide,sulphur_dioxide,carbon_monoxide"
  def url = "https://air-quality-api.open-meteo.com/v1/air-quality?latitude=${lat}&longitude=${lon}&current=${currentFields}&timezone=auto"
  if (logEnable) log.debug "Requesting air quality data from: ${url}"
  try {
    httpGet([uri: url, contentType: "application/json"]) { resp ->
      if (resp.status == 200) {
        def current = resp.data?.current
        updateAqi(current?.us_aqi)
        sendOptionalNumberEvent("pm25", current?.pm2_5, "ug/m^3", 1)
        sendOptionalNumberEvent("pm10", current?.pm10, "ug/m^3", 1)
        sendOptionalNumberEvent("ozone", current?.ozone, "ug/m^3", 1)
        sendOptionalNumberEvent("nitrogenDioxide", current?.nitrogen_dioxide, "ug/m^3", 1)
        sendOptionalNumberEvent("sulphurDioxide", current?.sulphur_dioxide, "ug/m^3", 1)
        sendOptionalNumberEvent("carbonMonoxide", current?.carbon_monoxide, "ug/m^3", 1)
        sendEvent(name: "lastUpdated", value: new Date().format("yyyy-MM-dd HH:mm:ss", location.timeZone))
      } else {
        log.error "Failed to get air quality data: ${resp.status}"
  } catch (Exception e) {
    log.error "Error fetching air quality data: ${e.message}"
// ===== Updates =====
def updateAqi(aqi) {
  if (aqi == null) {
    log.warn "US AQI data missing in Open-Meteo response"
    return
  def aqiValue = (aqi as BigDecimal).setScale(0, BigDecimal.ROUND_HALF_UP)
  def currentVal = device.currentValue("airQualityIndex")
  def currentAqi = currentVal != null ? new BigDecimal(currentVal.toString()) : null
  def threshold = settings?.minAqiChange != null ? (settings.minAqiChange as BigDecimal) : new BigDecimal("1")
  if (currentAqi == null || (aqiValue - currentAqi).abs() >= threshold) {
    sendEvent(name: "airQualityIndex", value: aqiValue)
    sendEvent(name: "usAqi", value: aqiValue)
    sendEvent(name: "aqiCategory", value: getUsAqiCategory(aqiValue))
    if (logEnable) log.debug "US AQI updated to ${aqiValue}"
  } else if (logEnable) {
    log.debug "US AQI change (${aqiValue}) within threshold (${threshold}); event not sent."
def sendOptionalNumberEvent(name, value, unit, scale) {
  if (value == null) {
    log.warn "${name} data missing in Open-Meteo response"
    return
  def eventValue = (value as BigDecimal).setScale(scale, BigDecimal.ROUND_HALF_UP)
  sendEvent(name: name, value: eventValue, unit: unit)
  if (logEnable) log.debug "${name} updated to ${eventValue} ${unit}"
// ===== Helpers =====
def getUsAqiCategory(aqi) {
  if (aqi <= 50) return "good"
  if (aqi <= 100) return "moderate"
  if (aqi <= 150) return "unhealthy for sensitive groups"
  if (aqi <= 200) return "unhealthy"
  if (aqi <= 300) return "very unhealthy"
  return "hazardous"
def getHubCoordinates() {
  return (lat != null && lon != null) ? [lat: lat, lon: lon] : null
Thanks for this driver, was trying to use it today to close my motorized damper in Michigan due to poor Air Quality Index from the canadian wildfire smoke . However I noticed the AQI and USAQI #s being reported are exactly the same at 78, yet the US AQI is currently over 400 in my area. I can write my routine to just use AQI (european scale) instead of US, but thought you might want to take a look if there’s something wrong here in the reporting of both values. US zip code 48188
I am SO sorry for my delay in response...
Thanks for flagging this. The driver was intentionally reporting US AQI in both the generic airQualityIndex attribute and usAqi, but that made the distinction unclear.
I’ve updated it with a Primary AQI scale preference: US or European. The main AQI and category follow that selection, while usAqi and europeanAqi always report their respective values separately. US remains the default. I’ve tested switching between both scales on my hub.
The difference between 78 and your local reading above 400 is a separate issue that this change doesn’t necessarily resolve. Open-Meteo supplies model estimates rather than local monitoring-station readings, so location, timing, and averaging can affect the comparison. I’ve also added the API data timestamp and clearer debug output to help investigate.
The updated driver and instructions are here:
After updating under Drivers Code, save your device preferences and refresh. Please check your automation thresholds if you switch scales.
