Only a blue light on new hub
Just got the hub. I only get a Blue Light. I have tried the troubleshooting options. reset network, reset hub, hard reset with the little button. Still only a Blue Light.
I can see the hub on my WIFI but can't do anything with it. No connection.
Can you access http://<Insert Hub IP Address>:8081
Sorry for the troubles. You may need a replacement. If you didn't do so already, be sure to create a warranty case by visiting the following page: Warranty – Hubitat Support
Try the diagnostic tool. Hubitat Diagnostic Tool | Hubitat Documentation
It runs on port 8081 even when you only have a blue light instead of green.
Normally you would do a soft reset, but since the hub is brand new you could also go into Advanced and do a full reset.
