As the topic says, I have my hubitat setup on the 192.168.1.xxx subnet many likely use. My WiFi is connected to the same switch and gets addresses from the same subnet. For some reason, after updating a few weeks ago, I can no longer log into my hub from the web browser on my phone. I get the first log in page, log in, and never see my hub listed.
Without totally restarting and resetting, any other options for getting this access going from my phone?
Are you, by any chance, using a "Guest WiFi Network" for your phone's connection? Most "Guest" networks prevent the connection to LAN devices.
I have this problem occasionally. I can log in but the entry for my hub is missing. What I do is after logging in, I type if the HE's IP address and works like a champ.
Sometimes I get the HE listed, other times I don't. I am wondering if it is a cache issue.
Not using a guest network. Same network I've always used and it worked.
I'll try using the IP address per spalexander68 and see what happens.
